Ok, so if anyone has followed the review sites for awhile, it's been standard to say on an AMD rig you wanted 2-2-2-10 for the best performance.. It's been like that since NF2 days, the same with the NF3, and now with the NF4 we see it go to 2-2-2-7..
So, blindly accepting this as the way it is, I set up my NF3 rig with 2-2-2-10 timings, as this should give the best performance..
One of the easiest ways you can see what your memory performance is, is to run memtest. It shows how many MB/s your L1/L2 cache does, and your ram.. Anandtech states this is typically the way they check to see which settings give the best performance..
Today I run some tests myself, just to see myself, as I needed to kill some spare time.. I used the latest version of memtest, 1.51, and checked it out..
My rig is a MSI Neo2, 3500+, OCZ 3200EL Platinum rev 2
So with 2-2-2-10 timings, memtest says I score a 2540 MB/s..
2-2-2-5 gives me 2698...
Oops.. If I'm not mistaken that means 2-2-2-5 gives better performance.. so I run through the rest of the settings.. here's a break down
2-2-2-5 = 2698
2-2-2-6 = 2618
2-2-2-7 = 2618
2-2-2-8 = 2540
2-2-2-9 = 2540
2-2-2-10 = 2540
2-2-2-11 = 2466
This goes in line with what should be happening in theory.. The lower the memory timings, the more performance you get..
To see if this is just a fluke, I run through some other benchs
EVEREST
2-2-2-5 = 5827 read/ 2233 write / 43.9 latency
2-2-2-10 = 5876 read/ 2507 write / 44.4 latency
hmm.. so everest is saying i have more memory bandwidth, but with reduced latency.. let's see what Sandra says
Sandra 2004
2-2-2-5 = 5799 int/ 5734 float
2-2-2-10 = 5785 int/ 5821 float
Hmm.. so sandra is kinda backing up Memtest alittle bit more..
So, just to get some non synthetic numbers, I try Q3 with the latest pointrelease
2-2-2-5 = 296.6
2-2-2-5 = 295.2
so, I do get slighty better performance in Q3 with 2-2-2-5.. Granted I ran the tests with 4xAA and 8xAF, but there was still a difference..
So, it would almost seem that all this time, atleast with the NF3, that 2-2-2-10 timings IS NOT the best option... I think that some benchs in their testing might be off, where it's mis-reporting the info.. Memtest is probably as raw as a program you can get, that doesn't get influenced by drivers, OS, etc.. And a realtime bench like Q3, which is VERY memory sensitive, does show a difference..
I'm going to re-run Q3 @ 1024x768 and no filtering real quick just to see if there is any difference, but so far I'm thinking lower does after all mean better for AMD64 rigs..
2-2-2-5 = 2698
2-2-2-6 = 2618
2-2-2-7 = 2618
2-2-2-8 = 2540
2-2-2-9 = 2540
2-2-2-10 = 2540
2-2-2-11 = 2466
EVEREST
Sandra 2004
2-2-2-5 = 296.6
2-2-2-5 = 295.2
