I have a D0 chip. Specifics are in my sig.
Also that "4.6ghz on air" chip won't last. He mentioned highest it would boot into the OS stable, not highest stable OC. I can get a large OC to boot into windows, but if it's not proven stable by stress testing then what's the use?
I'm extremely skeptical of his "under load not higher than 74C" figure as the Dark Knight isn't THAT good, especially at 1.55v.
I'm not sure any "exotic" combos will help you clock any higher. Chips are different and it's just luck of the draw.
Oh shit I thought you had a C0! I was like, DAMN that guy got a good C0.
Well I don't know much about VTT voltage and such. Right now I'm running at 3.8 at 1.375 vCore, P95 25 minutes and 84C top so far.
BTW, that push pin system on the Cogage is just pure D junk. The twist down are already worn out. One won't even stay tight. I just barely got it tight enough and then gentle put the case back together. This is the absolute last time i EVER use that system, ever. Waste of time. Would take my 10 minutes to mount the back plate. Took me an hour to wire the fan on and get the fucking push pins to work correctly. Idiotic.
So I need a cooler, or back-plate, for the Cogage. Wanna chime in on the V10 vs H50 debate? The thing I do like about the H50 is that it takes up such little space. I just don't think it will cool as good as the V10 under high temps, from what I've read.
