theDreamer
- Oct 11, 2006
So I have pitched a good idea to my company and they love it and want to do it. Basically it is a simple database linking all our reports we send to clients so we can search. I plan on using FrontPage 2003, but have not done any HTML for many years. Currently we have an excel file with all the information we want to be able to search by, or tag files with. My only thing is I am unsure of how to set this up and get the ball rolling.
~Want to use web browser (IE, Firefox, etc.) to do view
~We just need this internally
~I hope to start simple with just being able to create a search database where people can pick what they want to search by
~The final product will be a bit different, but I hope to have both side by side in the end (search and final)
~The database (and final) needs to be able to update easily. Where someone can input the needed tags and set the directory path to the file it links to.
The final product will be something along these lines:
~Load up page and you are looking at the continents
~Pick a continent and it zooms you in (or reloads the page) with the section you picked
~Pick a country (same as above), then a state, etc.
~At the final zoom level you pick from your choices, and it links you to the document opening in Adobe (we use PDFs)
This idea sounds very simple in my head, but with very little to almost no knowledge of HTML I do not know where to start.
Thanks for any help on this.
