Never done OC yet, but i am considering for next rig I am planning, and read a lot how great this board this is.
Can someone comment on that?
Thanks a lot~
DFI does not make good boards for beginners. There are just so many options, many of them dependent on one another; I'd start with a "simpler" board, and then perhaps sell it and upgrade later on.
Keeping in mind that half of over clocking is 50% experience, 25% component choice and the rest is pure luck. Nothing is ever guaranteed as to what results you will get or even what to expect.
Build slowly and carefully, make sure you have a big enough high quality PSU and cooling for the CPU and after that just have fun with it.
good luck with your build. my last, and only, 3 builds have been AMD machines. This will be my first Intel, and my first computer with intentions of OC'ing. I chose the 965-s as well (almost pulled the trigger on the evga 680i lite).
These will be nice trial by fire boards to learn off of.
I added my e-mail to item notifying e-mail list on Newegg.com... Hope they get some sooner or later~good luck finding a place that has them in stock
Wow... this is first "warning" I got, and thanks for pointing that. I will digg upon more detail but by chance anyone can provide some kind of route to start OC for newbie?The only thing about the DFI 965 board thats not beginer friendly are its voltage options.... It gives you options that will kill your components so carefull....... Most boards you can max all voltage option and be fine, but not this........
