Before I go out and buy another card for this, just want to make sure this is possible.
My Setup: 2 monitors on workstation and a TV out in the living room that I ran cable to, so my PC connects to it as well. My PC functions as a HTPC as well for the living room PC.
What I want to do is, clone my main monitor display to the TV, and then setup a dual monitor view with the second monitor on my desk. Basically, the TV and main monitor will have the same display and then I can drag windows to the second monitor.
I have a HD 6870 and found some limitations with what adapters you use at the same time. I was thinking of picking up a cheap 20 dollar card for the TV connection.
Is this even possible (hopefully I made sense)?
