So recently I've had a few clients in a neighborhood (a three block neighborhood) complain about internet connectivity issues. We have Insight Communications as a major provider in the Southern Indiana/Northern Kentucky area. It's a love hate relationship with Insight. I love my cable/phone and internet service I have with Insight. Currently I pay $50 / mo for their 20.0 which is a 20Mbps down / 5Mbps up service. I love it, never have any problems.
However I see a trend with this ISP, they are always half assing their tech support and telling their customers that "the problem is on their end." Recently I've been to 4 different houses in this neighborhood and they all had to get on the phone to Insight to get some tech support out there. Nothing.
I've sent my clients off with a perfectly working internal network with working PCs, made sure the configurations are correct and that they are satisfied when I leave. Then the evening hits that day (5PM-5AM), they start to get disconnects, bad latency in network applications, and so they call me and I tell them there is no way its anything on your end.
I've dealt with these scenarios so many times and in the end after tons of complaints to Insight from lots of people (this process can take up to 2 months) only then is a flag raised in the company that there is obviously a problem with the service they provide.
The downfall of all this is that it shouldn't take a months worth of complaints from about 100 users in the same area to raise a flag.
I've seen some of the bad cabling jobs these people have done outside their houses and beyond, the shitty cable modems they give them, or just the fact that the node that is used to support all the broadband connections in the certain area is very old/outdated/not powerful enough/faulty. Yet the company, to keep the customer at bay, just seems to blow it off as the customer's problem.
My best friend had the 20.0 service run to his residence, and it took them a month and about 10 phone calls and then 2 phone calls from me giving them an ear full to come out and get their shit together. Once a tech shows up (a private contractor ussually, they normally do a good job cleaning up what the ISP origionally ran) they normally see decaying cables, or cables that have been run too far from a support node and have attenuation problems with the signal.
Number one problem: The ISP sometimes doesn't give a damn because they don't want to spend the money to have the problems fixed.
THIS IS THE SAME THING with AT&T's service in my area. My friend can't afford insight's service so he's got standard 1Mbps/256k DSL run to his house that is slower than dial-up because AT&T won't send out the right technician to fix it correctly. His connection speed can't even make it over 125k and latency to servers on speedtest doesn't even go under 200ms. At first he had some great speed, but the line had attenuation problems because they ran the line too far and they had to reduce the speed so he could have a steady signal.
Theres my story. Now the questions:
1.Do any of you people have this problem with your ISP?
2.What is the best way to get an ISP to come out and truly sort out their problems and convince them its a problem on their end? How to deal with them?
I've done everything for these people from sending their tier 3 wireshark results, compiled bandwidth test logs, router logs, trace logs, that all show there is a problem outside the client's home. But they'll just use all sorts of excuses to point the fault at the user's end.
Where the hell do you find fault in network that as simple as: cable service's internet>modem>pc?
