cyberslag5k
- Jun 29, 2004
I have a new Asus display, and I really like it. I'm running it as the primary of two monitors, with a GeForce 6800GT. The problem is, when I set it to its highest setting, 1920x1080, which the monitor should support, the screen jumps up and down by like half a centimeter. It doesn't flicker, it literally jumps, and it's impossible to use like that. If I bump it down to the next lowest, 1680x1050, everything is fine.
Does anyone know what might cause this?
