I'm looking for comments/suggestions on my following idea(s):
Within the next month or two, I'll be building a completely new system from my current [sigged] box. I'm having trouble finding a case I really like that will accomodate my 240mm rad inside the case but I think the V1000 is finally one to consider.
Based on the above image, I would remove the hard drive enclosures and place both rad fans on the bottom of the case blowing out. The rad would be sitting on top with cool air rushing through and out. The air intake for the rad would come from the front 120mm case fan blowing in, and the remaining holes in the bottom of the case. Now I see a problem with this setup being that there are two 120mm exhaust fans and only one 120mm intake fan: negative pressure. Granted the holes on the bottom of the case to allow extra air to come in, but it would mostly be recycled radiator air.
The reason I want the rad blowing out is because it [, in it's current setup,] has created a dust sandwich with the fans, that impededs air flow. With the front case fan serving as intake with a dust filter, it would take care of this problem.
Finally, I'll need to place the HDDs elsewhere - which is where a 3-in-1drive enclosure comes into play. I've seen people recommend them but havent actually looked into them yet. It would take up the bottom three 5" bays and host another 120mm fan blowing over my three hard drives and into the case. This leaves me with two more bays where I'll leave one empty, and the other will hold my DVD-ROM/R/RW/CD-ROM/R/RW combo...
So I ask you, will my rad setup work or should I have the rad fans pull air into the case, and can someone recommend me a good hdd holder enclusure thingy?
