ScreamingBroccoli said:Thanks, you have just changed my mind out this case, seems kind of trashy now.
It's a very good quality case and a unique design (not trashy), just not practcial for my purposes.
spade357 said:Would you change your mind if someone came up with a modded one? It seems like a very moddable case compare to others.
ScreamingBroccoli said:When the PSU hangs from no support, that is trashy! I think I'm gonna get that jpac that newegg has. I don't care for the windows but it's the only thing that has what I want. Is there anywhere to buy some sort of black transparent plastic (something almost tinted I guess...) to replace the stock windows so the insides are a bit more subtle?
I don't get why you have the JPAC over the Micro Fly...the MF is cheaperScreamingBroccoli said:When the PSU hangs from no support, that is trashy! I think I'm gonna get that jpac that newegg has. I don't care for the windows but it's the only thing that has what I want. Is there anywhere to buy some sort of black transparent plastic (something almost tinted I guess...) to replace the stock windows so the insides are a bit more subtle?
Steeeeve said:I don't get why you have the JPAC over the Micro Fly...the MF is cheaper
neogenesis2004 said:Or cut some stuff up and fit a 2x120mm radiator in there like I am going to do.
reydio said:I tried my Ultra and Hyper Power Supply with no success. I got the black from NewEgg, now they are out of them. Hope this will help with you guys decision on buying this great case.
spade357 said:You can't install the Ultra? I'm getting the Ultra X2 for this case. That'll suck if it doesn't fit cause i really like their modular flexible cables.
gr!m said:I just ordered a black one of these the other day. Speaking of the Qmicra, I got this $100 shipped from NewEgg. I could buy almost 4 of these for the price of ONE QMicra (Although I have nothing against them). I will soon be posting my worklog on modding! Putting in front mount water cooling, LCD panel and more. Adding laser cut windows on each side.
