First off, thanks for looking as always
I am about to upgrade the Adaptec AAA-131U2 RAID controller in my video editing PC, and am considering either the Adaptec 2100S or the LSI MegaRAID Express 500. Both are single channel U160 cards, but the LSI comes with a battery backup and is substantially cheaper. Is there some horrid problem with LSI cards that should make me stick to Adaptec, or should I jump at the lower priced (and higher featured) LSI?
If it makes a difference I will be running 10k RPM Seagate Cheetah ST118202LWs in a three disk RAID5 setup in an external CRU enclosure with CRU Dataport VIIIs.
Thank you in advance for your help!
CJan
CJan
