xDiVolatilX
- Jul 24, 2021
It needs some fine tuning but pretty cool for being slapped together raw lol
not sure if the fittings would work for pc parts? maybe if you rig hose claps & such but this radiator desk if it were planned out better would be so cool I really liked this experiment.Just use a car radiator and save a few hundred after a point.
haha chucks of your knee caps would be flying off in due time and if you have the childhood habit of sticking your gum underneath the table like all elementary school desks then you'd be in for a unpleasant surprise lmaoI personally would never put a 3000 rpm fan (or any fan for that matter) right above my junk.
You can make any hole work with any fitting. Watercooling rads are excessively expensive. Half the reason I just use a heatercore from a car as a rad on my wc builds.not sure if the fittings would work for pc parts? maybe if you rig hose claps & such but this radiator desk if it were planned out better would be so cool I really liked this experiment.
My mates back in the old days would use the heater cores, we are talking 100Wish Athlon XP days though. Modern watercooling is ridiculously hand holding, which leads to issues when they don't top up/change fluid or monitor it etc as usual because they don't know or it's some AIO pos that you can't do anything to.Just use a car radiator and save a few hundred after a point.
Not too long ago LTT tried to cool a PC with a car radiator and it turned into a disaster. Granted it was the most jank job ever.Just use a car radiator and save a few hundred after a point.
