Ur_Mom
- May 15, 2006
I am looking to buy some home theater speakers. I'd like to go with a decent pair of front speakers (left, right and center). I'm looking at either Axiom, Polk or Klipsch. Budget of ~$1000 for the set.
But, I am unsure on the rear speakers. As they aren't nearly as used as the front, do they need to be matched? I plan on going with the same brand, but a model or two lower (in cost and apparently features). Would they still sound good in a movie settings (music will be 2.1 only for the most part)? It's a 7.1 setup. Subwoofer will be a custom build 15" Dayton HO model tuned to ~20Hz, ported with 500w BASH amp.
I could save some money by going cheap on the surround (well, cheaper than going with an additional grand or $1500 on the surrounds). Just don't want to really kill the audio quality or experience.
I don't think there will be a problem, but I wanted to make sure before budgeting out this system. I'll be buying in January. I will be using a Denon AVR-1912 receiver (don't want to go independent amps - keeping it simple).
