Currently using the Thermochill PA120.3 with panaflo H1-BX's, the issue is that my aquaero cant handle more than 10W on each channel so I ended up using the mcubed fan amp. The setup works however the control range and RPM is completly wacky.
I want all three fans on the same channel plus RPM monitoring for the aero, thats gives me two choices Papst 25mm and Panaflo 38mm L1-BX considering Papst 38mm with RPM are not available. Ive recieved the Papst 4412 F/2GL and they are very smooth with no bearing noise, I really like them however Iam cautious to go to 25mm deep due to the RAD.
Papst 4412 F/2GL Spec:
- Flow Rate: 55CFM
- 1600RPM
- Noise level: 26 dBA
- Input Power: 1.3W
- Flow Rate: 55CFM
- 1600RPM
- Input Power: 1.3W
