In-game play works fine with the devmode FPS counter, it just wouldn't run when I renamed the .exe to try to disable any optimizations causing weirdness. With how Crysis is running in the timedemo I am pretty sure something's up with the drivers. The timedemo is not running as well as the in-game gameplay is, which sends up a red flag right away that something's funky.
85-87c or so load so far.
I played some TF2 on Dustbowl and Goldrush for awhile earlier and honestly, while the max FPS didn't seem to reach as high levels, the minimum framerate was a bit higher seemingly than with the GTX 280 (never dipped below 60 with FRAPS running, max was somewhat lower, whereas the GTX 280 had dips to 50, of course due to the dynamic nature of the gameplay it will vary, but overall it seemed just as good if not better).
As far as IQ goes, you'd be hard-pressed to find a difference in the AF, but the AA seems a bit better on this card (8x MSAA on the 4870 vs. 8x CSAA of the 280), less screendoor effect from shimmering edges/etc. and the transparency AA is just as good. I am noticing less of a performance hit with AA than the GTX 280 was taking (note it was overclocked to 687core/1444shader/2400ish RAM).
I'm finding my results in actual gameplay with FRAPS running to be nearly identical, honestly. I am amazed with the quality of this card, not to mention its overclockability which I have a feeling is going to be insane once proper tools come out.
My newest stable overclock is as high as I can go so far: 25 loops of the flyby Crysis bench with me watching most of the time, reading a magazine the rest while snacking, at 4400RAM (1100x4 DDR5, stock is 900x4=3600) and 790 core. 100% artifact free. The CCC overdrive will not go any further , but this card is barely heating up more with the overclock than it was at stock so it should go much higher .
... but this card is barely heating up more with the overclock than it was at stock so it should go much higher .
You can always use Radeon BIOS editor if you know how. As far as the memory clock is concerned, that is impressive!
Don't get overly excited.... ya never know.
v1.11
* Fixed values written if look up table is used.
* Improved method of clock rates detection (old method was not working properly with some weired BIOSes).
* Added some FireGL device IDs.
* Added some stuff to the in-program-FAQ.
* Undated link to WinFlash.
* Fixed little bug occuring writing some BIOS infos.
* Fixed some confusion regarding 3650 cards.
* Added support for some exotic mobile card's BIOSes (experimental).
* Added support for HD 4850 (experimental).
* Added fan control for most 3870 X2s.
Well the 4850 one is out. Maybe try it out and see if it detects the 4870? Either way, it should be soon..
http://www.techpowerup.com/downloads/Utilities/RBE/
Radeon Bios Editor 1.11
People were achieving 800MHz on core for the 4850's... 900Mhz on water... I can't even imagine what an after market cooler (or water) + 4870 will hit
Nice going GT.
I bought the same 4870 and the driver will not load in vista. Trying like mad to figure out what is wrong.
EDIT: Purecain's XS thread has the goods on that. I'm up to 820core/1125(4500)ram now . I'm going to try pumping the core some after I test this more thoroughly.
where do u find the correct drivers for it i checked the amd website and the only drivers i see are the ones up too 3870?? can some one link me?
GT, you would be my absolute hero if you could do the following test for me...
Just oblivion, 1680x1050 16x AF, 8x AA with everything (grass, shadows, view etc.) set to max... Just stand in the middle of a forest on a nice day... And see what you tend to get frame-rate wise.
<3
So you got 820 on core without any volt mod?
You flashed them already? if your clocks are too high for the voltage it will not post, there is your issue. If you can perform the volt mod they will most likely work, I had a 4850 refuse too boot at 900 , raised the volts and it boots fine, the card with only 1 led is not getting juice, i bet it is your secondary right?
Yes.
I'm sorry guys, but the card died on me when I tried flashing to 870/4500 with a slightly higher voltage in BIOS... it worked fine for Crysis and others for about 15 minutes just running hot, but due to temps I flashed back to stock... suddenly bluescreen, now no boot... put in a card alongside it and it shows up in Windows, flashed to default BIOS with higher fan speeds and it won't come back to life still.
So, just a warning, don't go above 820 for now on the core and 4400ram, to be safe I'd stick with OverDrive's 790/4400 limit, the card worked 100% fine at that for ages and even 820, but you really don't want to end up without a card like me!. What's weird is at 870 core and 4500 ram, the card performed at least 30% better than it did at 850 core/4500 RAM, almost as though some bottleneck had been lifted... until it died . Now trying to find somewhere to get a 4870 from that I'll take better care of /cry. I wouldn't try going beyond 820/4500 which I ran for hours without huge temperature gains just yet... at least not with BIOS flashing and such, wait for RivaTuner/ATItool/anything.
Dammit, RIP. Mine should be here today, Fedex tracking says 6/27 by 3PM EST. Funny, its 6:10PM EST here and still no card yet.
I don't think they deliver past 9pm local time and even then i've never had anything come that late. Usually in my experiences if they aren't there yet, it probably got put on the wrong truck or something and you won't see it till Monday unless your local center is open tomorrow you may be able to pick it up.
Yea then ZZF is refunding my $27 for overnight shipping, thats BS, they sat on it too long. This was ordered weds with overnight. Now I wont have it till monday. ZZF FTMFL.
Sucks that you have to wait. I know how it feels to have your expectations shattered. I'm glad that ZZF atleast compensated your for the shipping. It also doesn't help that our shipping companies pretty much suck. UPS is my least favorite, but Fedex isn't much better and they are pretty odd. I can have 4 things coming to me via fedex on the same day, but depending on how its shipped it can arrive in 4 different trucks throughout the day. UPS (if they don't screw up) delivers everything on one truck or atleast in my area.
He said he wants them to refund the shipping, not that they have .
Oops, read that wrong. I hope they do, or atleast they should.
yea, I will just wait and see if by some miracle it shows up uber late. Its going on 10PM EST here - still no delivery, last note in trackign at 4:45 leaving Memphis TN. We dont have Saturday delivery here so I wont get it till monday. But ordering it weds with overnight should not have taken so long. I couldve gotten the free shipping and had it monday. Or ordered from Newegg and had it yesterday.
Im pissed off, never again will I order from ZZF.
