The problem started this evening when I reset the CMOS to defaults. Afterwards, the computer fails to get past the BIOS splash screen, and none of the keys on the keyboard would even work except for the Caps Lock. I heard the POST beep, but the screen remained frozen at the BIOS splash screen. I was completely unable to even enter the BIOS no matter what.
After letting the system run in this condition for a while, I noticed that the CPU HSF remained ice cold.
Here are the components in that system:
Intel i5-2400
Gigabyte GA-Z68MA-D2H-B3 v1.3 (U1b UEFI BIOS)
16GB (4 x 4GB) DDR3-1600 RAM @ 1.5V
GeForce GTX 560
Western Digital Caviar Blue 500GB WD5000AAKS
2 x 1TB Seagate 7200.12
1TB Samsung F3 HD103SJ
Lite-On DVD burner
Antec High Current Gamer 520W
I tried resetting the CMOS, removing the CMOS battery for an hour, disconnecting all USB devices except for the keyboard, even using the i5-2400's onboard video without the discrete GPU installed. I also tried running the system with only a single stick of RAM. All to no avail. I even tried to run the system without any RAM installed, but got error beeps. I even swapped in a different set of RAM, and a single stick from another kit, but the problem persisted.
At this point I suspect that either the motherboard or the CPU died out.
What shall I do? Please feel free to suggest something. I need this system to run tomorrow.
Intel i5-2400
GeForce GTX 560
Lite-On DVD burner
