Ok, so I put my old rig into a new case and use it for a websurfing box, specs are as follows:
Celeron D 315 2.26GHz Skt478
Gigabyte 8VM-533RZ mobo
Antec SP 300W PSU
512MB Viking PC2100
Netgear PCI wireless G card
Now, this setup ran around 32*C at idle in my Antec case, in this case it idled around 37*C. Being that it's a Prescott, I found this completely acceptable due to the fact I am using the stock Intel HSF and this case has no other fans in it aside from the PSU.
Now, I went into the other room to use this machine today and it was off... So I restarted, it posted, got to the Windows splash screen and rebooted itself again, and then after POST it just turned off. I thought that was weird so what I did was restart it, go into the BIOS and look at the temps. It's reporting a 75-80*C IDLE TEMP! The fan is spinning, I took the side panel of the case off, and the BIOS reports around 2300 rpm on the Intel fan, which I thought was a little low compared to the normal 2600-2700 it spins at.
What would cause this? I have all of the latest drivers and the latest BIOS for the mobo, and it worked fine in another case, as well as this one until today. I am stumped, but I am going to reseat the CPU and HSF and re-apply AS5 and see what happens. I am wanting to say a bad HSF but any other opinions would be greatly appreciated.
Antec SP 300W PSU
512MB Viking PC2100
