I just recently finished my X-QPack build.
AMD 64 3200+ Venice cooled by a XP-90cu
MSI K8NGM2-NBP
1GB (2x512MB) Crucial XMS (CAS 2)
Samsung 250GB SATA 3Gb HDD
evga 7600GT cooled by a Zalman VF900-CU
Samsung DVD-RW
Mitsumi Floppy & memory card reader
Antec SmartPower 500W PSU
The showy stuff is:
neon green UV reactive cable sleeving
2 x 12" UV CCFL
Sata connector with EL wire
The case is pretty quiet. The loudest thing in the case is the 120mm case fan in the back. Even at 7v it's slightly audible. I might replace it with a different one.
Here are my temps:
Idle:
CPU: 33*C
System: 34*C
GPU: 51*C
Load
CPU: 40*C
System: 37*C
GPU: 61*C
Pics:
This shows the part of the bracket I had to dremel away in order for the fan to fit
Another view of the clearance after the dremel fun.
Here is a low-light pic of the UV lights showing off the UV sleeving. I left some of the cable fully visible in order to show off the UV lighting. You can also see some of the Sata cable here. You can also see the Zalman VF900-cu cooling the evga 7600GT.
Here is the other side of the case where you can see the Sata cable again. This is an early pic during the build process, so it looks slightly different now. The main point of this pic shows how massive the XP-90cu is, and how much vertical space it takes up with the 92mm fan attached to the HS.
Just another angle. Nothing special, again, during the build process. I'll have to take some new pictures later.
Here are the latest pics taken through the window of the case in low-light:
MSI K8NGM2-NBP
Samsung DVD-RW
The showy stuff is:
2 x 12" UV CCFL
Here are my temps:
Idle:
CPU: 33*C
System: 34*C
GPU: 51*C
Load
CPU: 40*C
System: 37*C
GPU: 61*C
Pics:
