SoulCreatr
- Mar 3, 2008
So I built my current rig (in my sig) in the first week the x99 came out. Everything was great on the system until the last week or so when it has begun to have problems on cold boot.
When I first turn the system on all the lights come on and the fans spin but I will not get any video output. The LED light above the GPU stays on during this time indicating that there is an issue with the GPU. I have 2 monitors connected AOC 29" by HDMI and an HP 20" connected by DVI. No other LEDs are on, and I have run the memory test which comes back ok. The keyboard and mouse will both light up and the HDD can be heard spinning up like it is loading into windows. If I press the power button it will take a few seconds to turn off like it would if I was in Windows instead of instant off.
After I see this occur I can hit the reset switch or turn it off and try again. Eventually something sorts itself out and I will get video and everything works 100% as it should. I have no other symptoms and I have had this problem while overclocked and at stock clocks. The GPU is not new and I used it in my previous build for about 7 months, I have tested it again in my old system and it works. During all this the diagnostic LED readout on the motherboard just says AA which it says even when it's working correctly. Once I get the system to boot correctly I can reset it or turn the power off and back on without issue. However, after it has been off for a few hours it will have the cold boot issue again.
My hunch is that it is the PSU, but I wanted some other input before I go pull it for an RMA. Maybe a setting in Windows 8.1 that I am not familiar with? Any other ideas?
