Alright to make things easy for all of us here is what I am looking to do with my build:
I'll be doing high resolution gaming, even surround, photoshop, sketchup and autoCAD
my budget 1200.00
3) Where do you live?
live in hot Arizona! Currently have my current cpu under the h50, wondering the h70 will help.
Cpu, RAM, and motherboard, and budget allows ssd ( really want an intel 510 120g)
evga sli gtx 460's for now, 1tb hard for movies, files, etc, 500g hitachi sata 3 current o/s drive,fractal define xl, dvd burner, pny 9500 gt ( runs dells) and lastly my xfx 750w psu
6) Will you be overclocking?
Yes
I have a benq 241VW and two dell 2007fp, want to go to dell 3011 when budget permits
asap will buy piece by piece
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Would love raid, want also triple sli support, usb 3.0 and sata 6, esata, Bluetooth optional choice.
Have win 7 home 64 bit
my budget 1200.00
Yes
