Welp, did mine as well over the weekend. Replaced the Zalman 7700 with the NT06. Idle temps are the same 42-44c idle, and load is 3c higher at 56c. No complaints. This thing doesn't have a fan on it as I am using the 120mm fan from the PSU to pull the air over the socket. And the noisiest component in the setup is the GPU heatsink. Might be time to look at aftermarket coolers for the 7900GTX.
Overall thought, I am quite impressed. I knew the load temps would spool a little higher, and it is well within the chip's limit for load so I can hang with the "no noise" aspect of the cooler. In the Siverstone case its a perfect fit. There is about 1/16" space between the top of the fins of the heatsink and the bottom of the Power Supply. I'll have to snap some pic's so you guys can see the setup.
-E
-E
