New System - Windows problems...
cnealjr
Anyone ever had BSOD during a clean install of Windows XP Pro? Hardware is:
P4 2.8C
Abit IC7Max3 motherboard
WD 200gig ATA hard drive
1 gig Mushkin pc3500 level II memory
9800 pro vid card
Hard drive originally had Server 2003 on it, but was fully low level formatted using Western Digital's Data Lifeguard Tools, and I have tried installing as one partition and also creating a 40gig install partition and trying that way. Install will copy all files for installation and then give BSOD. I've flashed to the latest BIOS already. Any ideas/suggestions would be appreciated. Installing from a Windows XP Pro SP1 cd.
I had one that did that and it ended up being a bad stick of ram. It basically got to the same point of install every time and BSOD on me.
try using something like memtest to test out the ram.
Seems to be a memory issue, removed one stick and Windows is installing now, gonna run memtest86 and see what it says after I get install done.
