-=PESTILENCE=-
- Jun 10, 2004
I just read through the recent thread that was closed regarding underscan in the new CCC. I've found the settings and tried everything I can, but nothing I do is working. I have a Sharp 42" lcd tv, and until recently was running it at 1920x1080 over the VGA connection perfectly. Last night I installed Windows 7 fresh and when I got into windows, I get a "this resolution cannot be displayed" error. So I hooked up using the HDMI, and while it works and displays the desktop, at 1920x1080 it is underscanned, and text looks horrible. Tried changing the setting, but even when it's set to fill the monitor, text is MUCH worse than it used to be. Tried changing the stretch setting on automatic, but then the desktop is overscanned and the edges are cut off. I don't get a dot to dot mode under HDMI, used to get it with VGA.
I'm mostly annoyed at the fact that it worked perfectly under Vista, and now it just refuses to cooperate. Tried hooking up a 2nd monitor, but then the Sharp will only go up to 1024x768. Also tried different refresh rates.
Anyone got any suggestions? ATI Tool didn't work, and neither did Tray Tools.
