I don't know what happened, I turned off the PC last night, everything was fine, and today I notice that there is no speaker in the taskbar.
I go into sound properties and it says there is no audio device found.
I go into device manager and it say the auzentech cannot be enabled because there is a problem with the driver.
So i reinstall the drivers just in case, reboot, and still no audio.
Now it says windows cannot enable this device because there is a problem with the hardware, and there is a bug yellow exclamation point on the auzentech.
I try another PCI slot, still no audio.
I take out the creative X-fi, slap that in to make sure its not motherboard related, install the drivers and i get audio. Works perfectly fine.
I havent had this card but a few months, should I contact auzentech and try to get a new one? I have to check their site and see what it says about replacements..........
