theDreamer
- Oct 11, 2006
I figured this might be the best place for some questions about this case, as I know many here use it.
~What order does the SATA backplate follow to the actual drives?
~Did anyone else have problems with the fan divider, getting it in/out?
~The power cables for the hard drives and the fans, it seems my fan that goes directly behind the power connections will not fit. Same for anyone else?
~Do I need all the fans to cool all 20 hard drives? Would putting them on the other side work just as well?
So far the case looks great, and has exactly what I want. My only concern was, still is, this middle fan divider and how little room is between it and the hard drive enclosure. It took me a bit to get the fan divider out, any suggestions on what you did? Any other comments/suggestions about this case?
Thanks.
Thanks.
