Apparently today my video card decided to stop on me. When my monitor is unplugged it shows "No connection" and when plugged it just goes black and the power light goes amber.
Anyways, after I took out the dead card, I tried booting on my integrated video (for which I'm pretty sure I removed the drivers). It shows up on the monitor and goes through the mem check and IDE check but instead of loading XP it hangs on a missing NTLDR, CTL+ALT+Del error prompt.
According to web sources, the NTLDR is a missing/corrupt boot file on the hard drive.
I'm running HP's Media Center (w/ recovery partition) that came with the box, and of course they dont give a Windows CD for it. The only XP cd I have is for my old Dell's Home edition so it's useless for recovery.
Hitting F10 at boot to access the recovery causes the screen to hang at a blinking underscore prompt.
Is there any way that this is related to my failed VGA/driver-less integrated or do I have another problem on my hands, one with my OS HDD?
Today sucked, I'm completely out of ideas and desperately pissed off
