JGene said:No, you have to make 1368x768 on your own in the "Change Resolutions" flyout tab. I also tried PowerStrip and Rivatune, but in any case every time I try to set my monitor above 1280x1024 I get a pan & scan Virtual Desktop that's windowed to 1280x1024 or 1280x768.
If there isn't a solution soon, would eVGA work? Then again my TV's EDID data still limits it to 1280x1024, so I still might be in the same boat with another 6800 GT...
Sepal said:lower the refresh to 60 and it still wont go higher then 1024x768 ? sorry to hear that man.
Sell it as fast as you can to recoup some fundage and get something else that you can live with. GL
FlyinBrian said:on bfgs website under FAQ i found this...
Q. Is there a maximum resolution for the DVI output?
A. Yes, it is1280x1024.
JGene said:Here is another thread that I posted in. Basically another guy who is stuck running at a lower, windowed Virtual Desktop because of nVIDIA forcing EDID compliance. If you could, give the engineers a good holler and if possible give me a few telephone numbers.
I've been using my TV for two months at 1368x768 on my old Radeon 8500. I would expect that a $400 video card could replicate what my 3-year old ATi card could easily do, but this is leaving a sour taste in my mouth.
EekTheKat said:Bar + JGene appear to have problems with custom resolutions on Widescreen LCD's and LCD TV's. This appears to be an entirely different issue than a 6800 GT being unable to drive LCD's above 1280x1024.
EekTheKat said:I believe BFG's technicians that you've spoken to are not exactly informed and not exactly knowledgeable about the 6800 series of cards yet.
Bar81 said:How would I be able to find out the EDID my monitor is reporting? It always reported the proper max resolution using the ATI drivers
edit: I can't really help above 1280x1024 as my monitor maxes at 1280x768. Sorry.
FlyinBrian said:HMM i have a theory, Overclocking can cause you to get a dirty signal, just for testing purposes set your clock/memory to nvidias default listed speed, reboot and then see if you can get 1600/1200
Sepal said:ati has that, ' use alternate dvi operational mode'.
does nvidia have something like that ? im just grabing at straws because its
bugging the she-ite out of me that this happens at a common rez setting.
EekTheKat said:Few questions for you guys unable to hit 1600x1200, which I guess would only be the author of this thread:
Is your monitor properly detected?
Are you trying to force your LCD to run anything besides 60hz?
OH NOES! I better send back my BFG 5900 because it runs at 1600x1200 on DVI. You're a troll.FlyinBrian said:on bfgs website under FAQ i found this...
pxc said:OH NOES! I better send back my BFG 5900 because it runs at 1600x1200 on DVI. You're a troll.
Yes, you are a troll. You first post in this thread was one and your continued spreading of misinformation also makes the label fit. That's not the 6800GT FAQ, that's the general FAQ that's been on the site even before the 5700s/5900s came out. The most current card mentioned is the 5200. Several items are wrong and/or outdated:FlyinBrian said:Please dont call me a troll, Nothing i said in the previous posts warrants such a label.. perhaps you should review all of my posts in this forum before commenting.
Go to Bfgtech.com look under FAQ for the 6800 GT and you will find the thing thats says what the max dvi output is.. now please from now on do your research before calling someone troll... thank you
pxc said:Yes, you are a troll. You first post in this thread was one and your continued spreading of misinformation also makes the label fit. That's not the 6800GT FAQ, that's the general FAQ that's been on the site even before the 5700s/5900s came out. The most current card mentioned is the 5200. Several items are wrong and/or outdated:
http://www.bfgtech.com/faq.html
Q. What size power supply do you suggest for running a BFG graphics card?
A. While a quality 250watt power supply should work, we highly recommend 300watts (or above) with a combined minimum of 165w to be safe.
<the newer cards' spec pages clearly show a minimum of 300W, outdated>
A. Yes, it is 1280x1024.
<wrong/outdated for the MX440, even earlier cards than the 6800 support 1600x1200 on DVI... I'm running that right now on my 5900>
Q. Is there a maximum resolution when using the TV out function? Is it different on an HDTV?
A. The maximum output is 800x600 for a regular TV, for an HDTV two maximum resolutions are supported: 1280x720 pixels in progressive and 1920x1080 pixels in interlaced.
<wrong/outdated for the MX440, the integrated TV encoder on the NV3x series supports 1024x768, earlier cards with certain external encoders supported a max of 800x600... HDTV support is correct, but I don't think BFG ever supported that on the NV3x cards>
And yes, your only appearance in this thread is to try to stir up trouble and spread misinformation, the definition of a troll.
pxc said:Yes, you are a troll. .
damn, this has me worried now. I just got my 6800gt from BFG in the mail today. I'm still at work so I can't test this, but i have a 2001FP. It better f'n work, grrrr.
I think others have the same success you do, but what do I know? I only run DVI 1600x1200 on my BFG card.EekTheKat said:It works. I run this very exact combo and it works.
gt3t said:I have the same problem with the BFG 6800 GT OC and Samsung 240t monitor not going beyond 1280 x 1024. Borrowed a friends Dell 2001 fp . WORKs GREAT at 1600 x 1200. Problem must be with the Samsung monitor. DUH
