WickedWeasel
- Jul 13, 2004
I am using an nvidia card now, and I noticed all of the drivers since 170? and up no longer have the small Color Correction at the bottom of the task bar. I have lost hope that nvidia will ever bring that back.
The reason I use color correction is that my desktop is usually dark because it is easier on the eyes. When I am surfing, or watching trailers, I usually quickly open up color correction and adjust the brightness or gamma, and when I am done, I cancel to bring the destop back to being dark. Color correction at the task bar is much more efficient for this adjustment because it is small and I can keep it open while doing what I need to do temporarily. Opening up nvidia control panel takes up the entire screen and it forces the fan to spin up to 100% which is very noisy.
I have never had an ATI/AMD card, but that may change.
Question: Does the ATI/AMD card have a feature that is equivalent to the nvidia color correction that allows me to have QUICK access to make temporary adjustments by opening up a small pop up menu?
