hey all. got some questions, need some answers.
i've got me some new ram as you can see from the title, and my specs in my sig. it seems to me i have a heat problem with these TCCD sticks. all this time i thought that BH-5 ram (which i had before) were the ones to need active cooling cuz of hte volts they took etc, but right now, it would seem im hitting a OC and voltage wall with my ram.
i cant run at 250 mhz on the ram with more than 2.6v as it gets too hot and errors out on memtest. and because i cant run more voltage, i cant tighten my timings. so im currently running at 2.5-4-4-10 for my stability.
am i correct in thinking that anything above 2.6v at this speed range will overheat the chips causing them to be unstable?
is there something i dont know about TCCD memory overclocking? need help from the experienced TCCD guys. hopefully those on a msi neo2 plati mobo as well. i say that because to get dual channel the sticks have to be beside each other, which makes their heatspreaders touch.... making them HARDER to cool with regualr case airflow (my reason for upgrading from the bh-5 ram)
