Abit667 said:Shouldn't it also be on MS?
diablo111 said:http://www.microsoft.com/downloads/...BE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
This link is on the hardocp frontpage...looks official to me
Sounds like the same deal SP1 was. You could either run the express installation from windows update or whatever or just download the "Network install" version and run that from your computer. I don't think there is anything different with this one, of course aI could be mistaken. Either way I just downloaded it and I'll probably try it out later, that or just slipstream it and keep it for the next install.Scythe said:So, no problems installing the network SP2? It may be bigger, but what would the differences between this one, and the single computer version? (Other than support to mirror or push SP out).
Has anyone installed this one?
Scythe said:but what would the differences between this one, and the single computer version?
Is it complaining about AU, AV, or firewall?Komataguri said:Now I'm stuck with this security alerts shield thingy sucking up resources and not able to get rid of in my active tasks down by the time clock.
Rename your folder back to the way it should beKomataguri said:Also, the messenger beast hath returned. Had to go back and rename the folder once again to XMessenger to prevent it from loading when anything Macroshaft made loaded.
http://vortex2050.dyndns.org:8080/repository/Patches/Uxtheme/Windows XP/SP2/Komataguri said:Also fubared my hacked UxThemes.dll, my beautiful themes no longer work and I'm stuck on default green and blew XP default.
sarcastic6 said:Is it complaining about AU, AV, or firewall?
sarcastic6 said:Rename your folder back to the way it should be
Start, run, "RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove" (no quotes, of course)
Poof, gone forever
Sweet deal.sarcastic6 said:
