I bought an el cheapo ASROCK mATX mainboard for websurfing & DVD at home after my IC7-G crapped out on me.
The board supports an 1.5V AGP 8x slot (not 3.3V as mentioned in the manual a couple of times). AFAIK my 9700pro should be absolutely fine with that, as it operates with 1.5V when in 4x mode or 0.8V when in 8x mode. It, too, has the notch indicating it is 1.5V mode compatible., yet, whenever I plug it into the AGP slot the system will not boot at all, not even POST, no beep, nothing.
Everything runs perfectly fine with the onboard VGA, but I'll not be able to hook it up to my TV so I need the add-on card with S-Video out (at least as far as I know). Any ideas of what I could do wrong here? There is not even a jumper to be set on the bloody board as it is supposed to detect add-on cards automatically...
