Anybody have experience with the Onkyo HT-S9100THX? I got it ordered just trying to make sure I have all the neccessary accessories to make the connection smooth.
I already ordered the replacement speaker wire as I understand the stuff that comes with it is junk.
Looks like it requires the 3.5mm to RCA adapter for analog usage.
Would I be better off using THX optical from my Prelude and let the Onkyo do the digital to analog conversion? My old speakers were Z5500's and I personally found the Preludes DAC/opamps made superior sound but it will probably be less of an issue with the higher end system. The only issue with using an optical cable would be with conversion lag but I don't recall that being an issue when I used it with the Z5500.
Any other tricks I need to know about?
