-=PESTILENCE=-
- Jun 10, 2004
Ok, I had a pair of 1950xtx's and everything was running fine. Just got my 3870x2's from newegg today and put them in my system. Decided to remove the driver and run driver cleaner. Did a reboot and installed the drivers on the disc. Restart and i get "External Event Utility has stopped working". And I couldn't run the CCC.
So I uninstalled again and ran driver cleaner, did a reboot, and installed the 8.1 Drivers off the ATI site. Same thing. Kind of at a loss here. I tried looking online and some people say its a .NET problem, some say its a firewall issue.
I'm running Vista 32-bit, don't have windows firewall enabled, and I tried installing a .NET fix but it says its already part of the OS.
Any help would be appreciated. I wanna get these cards running perfect before I test em out.
[UPDATE]
Fixed it.
Uninstalled everything and then installed the drivers off the disc. got the error. So i went into the administrator properties and took a look at the services. I started the external event utility by itself and it started up, and I was able to run the CCC. ended up setting the options for it so that after the first time it didn't start, it would try to restart the service. then the 2nd time, etc. Now it's ok.
Now I have a different issue though. Ran my 3dMark06 and only scores 10,456. I have a Q6600 2.4ghz, ddr3 memory, and the 2 hd 3870x2's in there. I know the crossfire doesn't work, but I've seen people with crossfired 3870's getting about 17k marks...
Also, I don't have an overdrive or crossfire tab at all.
I think something is definitely up in driver land...
[UPDATE]
Fixed it.
