It's still around, although it seems to have stalled at v8.. You really ought to have a look at PartedMagic. It works very well, very reliable and in my experience is faster than most of the "pay for" variants....
Partition magic used to be great for me, after I installed Vista I found that it doesnt support it (though I guess the current version supports it)
now i'm using this thing
Paragon Partition Manager, 8.5 Enterprise Server Edition
really nice and supports everything
You need to be more specific with how your drive is currently configured. Unless you do a repair install, you'll be reinstalling all of your apps. You should also have a second physical drive, or an external drive to copy your data to, such as mp3s, pictures, etc, to keep them safe. Either way, Partition Magic isn't going to help you to reinstall the OS. Until you give specifics, we can't really go any farther.But I want to keep what's already on my harddrive and not have to reinstall the stuff again. I just want a fresh install of windows, while keeping all my files. Is this possible?
Is there a specific feature you need that isn't included in VirtualBox, which is free?I also snagged a like-new unused license copy of VWware Wrkstation V. 6 for $105 bucks.
PartedMagic is free, and honestly works a lot better than Partition Magic in my opinion.
And yes, it will "delete" the partition your old OS is on....
