Fark_Maniac
- Feb 21, 2002
Below is the meat of the code of what I'm trying to accomplish. What I'm doing is editing data base content from a form. The form passes all data as POST, I retrieve the old information and compare the two. If the data was changed, then I will (eventually) build a string that I will use to update just the fields that were changed.
I've done some googling and found out about the foreach($res as $key => $db_value) thing and thought it was pretty slick way of getting this accomplished. What is not working is the ($value != $_POST['$key']) comparison. My output states that all values have changed. Following the code is an output of what I get.
Key: isbn Value: 0-8041-1998-8 Post: 0-8041-1998-8 First
Key: title Value: Phantom Warriors: Book One Post: Phantom Warriors: Book One
Key: author Value: Gary Linderer Post: Gary Linderer
Key: backing Value: soft Post: soft
Key: fin Value: yes Post: yes
Key: comments Value: Book one of a Vientam LRRP, LRP, and Ranger series Post: Book one of a Vientam LRRP, LRP, and Ranger series. EDIT
Key: book_type Value: viet Post: viet
PHP:
$sql = "select isbn, title, author, backing, series_num, fin, comments, book_type from bookinfo where ISBN = '$_POST[isbn]'";
$res = mysql_fetch_assoc(mysql_query($sql,$conn));
$build = "";
$point = 0;
$count = 0;
{ $esc = mysql_real_escape_string($_POST[$key]);
if(($db_value != $_POST['$key'])&&($point==0))
{ //If the value of key does not equal what was passed and this is the first, start building the query
//$build .= "$key=$esc";
echo "<strong>Key:</strong> $key <strong>Value:</strong> $db_value <strong>Post:</strong> $_POST[$key] <em><strong>First</strong></em><br>";
$point++;
elseif(($db_value != $_POST['$key'])&&($point>0))
{ //If the value of key does not equal what was passed and this is the second edit, continue building query statement
//$build .= ",$key=$esc";
echo "<strong>Key:</strong> $key <strong>Value:</strong> $db_value <strong>Post:</strong> $_POST[$key]<br>";
$count++;
