Hi!
I just traded for a 6800GS (great trader btw, definitely not a troll thread). But I noticed some things:
The temps are 48/68'C with the ambient sensor saying 38'C. I have a Zalman VF900Cu on hand but I need to buy RAMsinks which might cost $10.
When I OC manually, I can reach 540/1200 (stock is 425/1000). But that OC is not stable. Letting it detect the optimal clocks gives me 520/1200, which crashed, only once though. I lowered it to 500/1200 and I have yet to test it.
I noticed that the artifacts are different from those on my traded 6600. On the 6600, they would be random colors popping up on the models. On the 6800GS, the picture basically messes up very badly. It's like one small picture tiled across the screen (sorry, I can't describe it any better).
So is this stuff to be worried about? Should I buy RAMsinks and slap on the VF900? Also, can you post yoru 6800GS OCs, if applicable?
Thanks!
Thanks!
