lil layzie
- Jan 7, 2004
First, the hardware:
XFX Radeon HD 6970 hooked up via DVI cable to my Asus VH236H monitor. Top DVI connector to be specific.
I also have my Sony HDTV hooked up to my video card via HDMI for duplicating my desktop for movie viewing.
The situation:
I wanted to revert back to the old Catalyst 11.11 drivers because I noticed when exiting some of my games on Steam with the Cat 11.12 drivers, it hangs for a bit before completely exiting the program.
This is what happened when I uninstalled the Cat 11.12 drivers and installed the 11.11 drivers. Same thing happened when I tried to install 11.10 drivers. Note the pictures are taken while I'm running on the 11.11 and 11.10 drivers. Everything is peachy on the 11.12's.
At first I thought my video card was dying. I couldn't see anything so I had to use the win key + p to duplicate the screen onto my HDTV and I was able to see my desktop. Uninstalled the 11.11 drivers and reinstalled 11.12 drivers. Everything is back to normal.
I tried to revert back to the 11.11 and even 11.10 drivers and the same problem still occurs. The method I used to uninstall the 11.12 drivers is by using the uninstaller in the control panel. I even tried driver cleaner and CCleaner to no avail.
Does anyone know what can be causing this? I can't use any older drivers, but I can install the 11.12 drivers without a hitch. My card is not overclocked so I don't know what can be causing this.
The situation:
