response99
- Oct 22, 2006
I have a Ultra X-infinity 600w PSU, and it is LOUD.. is there anyway that changing the psu fan will change this, or is it the psu its self.?
response99 said:I have a Ultra X-infinity 600w PSU, and it is LOUD.. is there anyway that changing the psu fan will change this, or is it the psu its self.?
response99 said:doesn't mention anything about noise..:S
jonnyGURU said:The review doesn't mention anything about noise because it's not supposed to be a loud PSU. Obviously either your PSU fan or fan controller is defective.
dbTelos was suggesting the review because it has shots of the insides so you can see what you might be getting yourself into when replacing the fan.
But I don't suggest replacing the fan. You have a PSU with a lifetime warranty that can be replaced via an advanced replacement so you would have ZERO down time... I wouldn't throw that all away by replacing a fan when it might not even fix your problem.
If the problem is the fan controller or you wire the fan directly to the +12V, then ANY FAN is going to spin at full RPM and that simply isn't the way PSU fans work.
It's just beyond me why people don't take advantage of things like advanced replacement RMA exchanges. Just call the toll free number and get it replaced.
response99 said:Thanks for the help Jonny, i'm going to call them today. Should i just tell them its extremely loud, and the fans are spinning at full rpm all the time? or something else.
response99 said:I finally contacted Ultra about this stupid psu. they gave me a code:
Defective # 5408
anyone know what that code refers to?
