snowysnowcones
- Apr 2, 2006
Really hope that ATI has something on par with Nvidia's offerings. We need a good ol' fashioned price war in this industry.
HD3870, "yeah ill believe that when my shit turns purple and smells like rainbow sherbet".
I will boycott AMD/ATi if they decide to mix it up with the numbers like that. Which they won't since they spend millions of dollars on marketing which would know thats stupid to call something the HD3870. I was pissed off enough when they went from x to HD.
I think the fad of using X's to make the product look "more eXtreme" has finally worn off.HD3870, "yeah ill believe that when my shit turns purple and smells like rainbow sherbet".
The RV670 chips should perform better than the R600 chips.A new generation name for a refresh? It hardly looks like a refreash, more like a die shrink, and they cut the bus in half. This looks more like a step sideways than anything else.
So your THAT worried about numbers? You must have a simple life to let something like that get you fired up..
Remember the glory months of the X1900? Methinks ATI will have some of that glory again soon, and it won't hurt the customer's wallet as bad either.
The new, much improved, much less expensive product really does deserve and rate a new naming scheme.
I've got a feeling that they are way better than even ATI thought they'd be. Enough better to justify new line plus I do agree that they want to distance from 29xx. 256 bus is plenty. Don't forget clockspeed plus refinements.
On paper, R6xx should be a monster. Maybe they figured out how to move it from the paper?
nösferatu;1031563620 said:no, i don't remember that, i remember the glory of 9700, without "x" or "HD", but...well, maybe that's not in your age.
They are probably renaming it to the 3000 series to get these new cards as far away from the stench of the 2900XT as possible . Unless, of course, these new cards suck too...
Skipping a die shrink is probably sufficient to warrant a 'generational' shift in product nomenclature for marketing purposes. I would do the same in AMD's position. Seems like they're doing that throughout their product range this year, which is an overall good if not necessary strategy.I've got a feeling that they are way better than even ATI thought they'd be. Enough better to justify new line plus I do agree that they want to distance from 29xx. 256 bus is plenty. Don't forget clockspeed plus refinements.
Don't forget DX10.1 shader model 4.1 and PCI-e 2.0. More and more I can see the 3xxx being justified.
The 850Mhz part could well OC to 1Ghz. I don't think anyone would argue that an extra 75-100Mhz is built in just for headroom which the OC'ers will immediately exploit. From there it might take an aftermarket air or possibly watercooler but 1Ghz will fall with this card.
If the rumors are true........
Plus, if 10.1 adds mandatory 4x AA....................interesting.
I'll gladly go back to ATI next gen if they can get something decent out.
