A mixture of these questions I'm about to ask have been posted already, but not altogether to arrive at the ideal setup for me. So I have to ask...
Here's the remit:
- I have enough physical space for 2 SATA1 hard drives,
- the PC is used primarily for games performance, but will also be used for video capture (vid camera), editing, then finally burning to DVD,
- 2Gb of RAM will be installed,
I've read about the WD Raptor 74Gb being the dogs bollocks, but 74Gb is a bit measly when it comes to todays storage. Using 2 Raptors is a bit expensive for the storage obtained, although I'm unlikely to max out +140Gb though as my music is on a separate server.
At the moment I use RAID 0 and like the performance from it, but I read conflicting reports about the Raptors in RAID 0, as in it's not worth it. Then the topic of the week is where do you store your OS, apps, games, pagefile and captured video files if you use separate drives.
So:
1. Is 2x Raptor Raid 0 worth it from a performance pov? I know the risks and backup often!
2. Would partitioning the above cause any performance loss?
3. Would 1 Raptor and another hd of greater size, non RAID be better?
4. From reading the threads, I'd put the OS and apps on one drive, and the pagefile, games and captured video file on the other drive, sound ok?
5. Is the orientation of the hard drives important? I'm hoping to install them vertically; the connectors of one facing down, the other's up. Get me?
Thanks in advance.
Here's the remit:
So:
Thanks in advance.
