Since theres no difference between soft shadows on/off it means hes using AA... 48 avg framses at 16x12 4xAA is a bit impressive i think
bobrownik said:i will not post any more benchmarks because obvoiusly those are not correct , since my card doesnt switch to the right clocks
if somone can figure out why the card doesnt switch to 625/725 clocks when running 3d then i can benchmark some more
or until a new cat is released that supports x1900 cards
it looks like this card can do a lot more then we all thought from the first benchmarks that i have done
Frostwake said:Since theres no difference between soft shadows on/off it means hes using AA... 48 avg framses at 16x12 4xAA is a bit impressive i think
asmielia said:All I have to say is Wow! Thanks a lot for the benchmarks. Looks like there's definitely an issue with the clocks, but even with that issue (and the fact that at 600/700 you're still underclocked from the default 625/725), you're beating out an nVidia 7800GTX 512 SLI system according to these benchmarks:
Anandtech 7800GTX 512 review
Keep em coming
Adrian
heatlesssun said:Not exactly. That Anandtech score for F.E.A.R. 1600x1200 4aa is way off. My average frame rate on the sig rig in SLI is around 63fps. Not sure why there score was so low.
asmielia said:Well, your BFG cards are overclocked out of the box for one. That probably accounts for at least 5 fps right there. Who knows really.
We'll know for sure how it stacks up once a proper review is out and a standard system is used for all video cards, but for now, things are looking very good.
Adrian
bobrownik said:also remember that i tested with the fear multiplayer DEMO,
and that some textures werent rendered right , like the fire , and the wall texture on the right side of the water , it looked too blocky
5150Joker said:Just ordered the X1900XT + overnight shipping! Does anyone know whether or not the X1900XT and 7800 GTX have the same fit for a water block? I was using a maze 4 on my GTX and plan to do the same with this card when I get it on Wed. Going to do some benchmarks with the GTX tonight and then send it off to the guy that bought the GTX from me tomorrow morning.
