Mr. Miyagi
- Sep 21, 2004
Is there a way to resize the window when running Counter-Strike: Source in windowed mode? I see that you can only increase the size of the window by changing resolution. I would like to use the 800x600 resolution but the ability to resize it. You can maximize it, but the image becomes corrupted.
The reason I'm asking is because I just purchased a Samsung SyncMaster 2233RZ and it only runs 120Hz at native resolution (1680x1050). If I try to run at 800x600, even running through ATI image scale, it will only display at 60Hz. There is no way to force the refresh rate like you can on a CRT. If I can just increase the size of the window while running at 800x600, that would be great. Or if anyone knows of another way, that would be great. (I tried screen magnifier and that didn't work)
