So would you be insulted if someone put it on a 8mm loop with a DDC? I am going to buy one from Swifty but don't want to insult you too. Worst case I will run a 10mm loop since it will slip over a 3/8" barb. I am very interested in the performance, if I can get the pump to push hard enough.Cathar said:I personally agree, 1/2" is way too big.
For all waterblocks, performance is a function of the liquid flow rate and the incoming water temperature, and all the tubing does is supply the flow of liquid. The smaller the tubing is, the more of the pump's work is spent just pushing the water through the tubing, and so flow rates will slightly decrease. How important that effect is, is a matter of scales.
One of the benefits of the Storm waterblock is that it achieves its cooling performance without requiring flow rates as high as traditional 1/2" ID focused waterblocks, which is also one of the reasons why Swiftech chose it, as it fits in with their policy of "moderate" flow rates as is suitable for 3/8" ID tubing.
When I designed the Storm block, I wanted it to be used happily with 3/8" ID tubing, and even 5/16" (8mm) ID tubing if people wanted to, again because I also think that 1/2" ID tubing is too big, and quite frankly, unnecessary. The largest tubing size that I readily recommend to be used with it is 7/16" ID tubing stretched over the 1/2" OD barbs.
So to answer your question, 3/8" ID tubing is fine. The Storm block does NOT require the high flow rates that 1/2" ID tubing traditionally supports to achieve its high level of performance. 3/8" ID tubing is perfectly capable of supplying the flow rates that the Storm works well at without offering a significant source of restriction to the pump.
Switching 1/2" ID for 3/8" ID would be unlikely to cause an increase of CPU temps by more than 0.1-0.3C for the scenario you specifically highlighted above.
Dropping down to 8mm ID tubing would be unlikely to increase CPU temps by more than a further 0.5C.
i.e. The difference between using 1/2" ID tubing and 5/16" (8mm) ID tubing should be no more than 1C, with 3/8" ID tubing being much less than that.
May I suggest that rather than using the MCP655, that perhaps you could instead use the MCP350 with its native 3/8" ID tubing support?
