Fark_Maniac
- Feb 21, 2002
I've built my first SATA RAID setup and things are running smoothly. I'm using Seagate's 7200.10 80GB drives. I jump into the raid configuration utility and notice that the disks are operating at 1.5GB/s and NCQ is disabled.
While i've never built a raid array before, I know I need to get the speed up to 3.0GB/s. Would there be a reason that NCQ is disabled by default?
This PC is RAID1 so that the drives are mirrored. The group I built this for has applications and data that cannot be lost due to hardware failures. I figured both drives won't go south at the same time, mirroring should work just fine for that level of data protection.
thanks for any help.
