Does this mean I should get a SG05 rather than a SG06? I was leaning towards a SG06 because the fan isn't visible on the front and has golf blades. Is it really more quiet? More importantly, could a SG06 handle the configuration I'm planning (860, 470, etc.)?
I don't include acoustic and cooling tests anymore because they aren't as useful as you might think. I used to do acoustic tests in an Anechoic chamber at a major research institution. The professor who was helping me and I basically came to the conclusion that the more fans the louder it is. The design of the case does cause a small change in volume but is normally not noticeable by the human ear. The materials generally just change the pitch. Steel makes for a lower while aluminum has a little more ring to it. The number of vents also makes a little bit of a difference.
In short, sound levels are basically obvious just by looking at the case and are not much different give the same number and type of fans.
Cooling is much the same way except that the biggest difference here is what heatsink you are using and how much heat your equipment produces to begin with. After reviewing a lot of cases I found that, get this, the more fans the cooler it was. There is rarely a big difference between different SFF cases since they are so limited to begin with. Probably the biggest differences will come with (in this order) what heatsink you use, what season it is outside, how many fans, and what kind of fans. I think thermal imaging is probably the better test in a computer case so you can see hot air pockets.
The SG05 has a 120mm fan and that's it. It also has a lot of open holes on the sides which create noise..mostly from the video card. This just is what it is.
I'd agree that some materials insulate noise. Like I said, steel tends to absorb the higher pitched noises better. This is obviously negated if you have a lot of vent holes. In SFF computers you generally have a lot of vent holes. I've tested a lot of cases from the Antec Aria to the Qmicra to the SG05/06 and found very little difference in cases with similar number of fans. Apparenlty many people feel a low rumbling noise is "less" noise when it really is the same. This is why the steel cases do better.I have had some different experiences regarding noise and cooling.
More fans more noise, yes but some materials can actually insulate the noise. Also depending on the fan mounts vibration and thus resonance can be mitigated to a point.
Case cooling is a much more complicated issue. Actually using many fans can harm the thermal design of a good case if they are setup in different directions. A big advice to everyone is to keep the air flowing in one direction. I have seen setups with intake fans everywhere. Thats not going to help, It's gonna cause a lot of turbulence and even if temps are acceptable under load it's gonna take a lot of time to remove heat from non actively cooled parts of the case like the mainboard itsef
Rejoice! A review is out
http://vr-zone.com/articles/vr-zone-exclusive-silverstone-sst-st45sf-450w-sfx-psu-reviewed/8805.html
EDIT: lol! they were drawing 530w from it all night, thats very impressive that its still stable after that sorta torture.
Pretty improperly done PSU review. No ATE for load testing and no Oscilloscope to measure ripple. The power meter they used looks a lot like the Kill-A-Watt and that's been shown to provide inaccurate readings with PSUs with APFC.
Unfortunately not even PSU experts or people who tests PSUs for a living know why a KAW provides inaccurate numbers. All they know is that it does and that you have to take those numbers with a grain of salt.Not everyone has big PSU testing gear, I still don't get why a kill-a-watt would be inaccurate besieds for not taking into account efficiency.
Good news everybody
they're starting to stock the ST45SF
from google: Sundialmicro (never heard of them)
80 shipped would be a nice price. Also please send me some pics of your rare case, Im curious as to what it is.Wasn't the MSRP $10 less? $80+shiping is too much for me. If I can get one for $60 out the door, I'd buy one in a heartbeat! I could use it to ressurect my rare aluminum mATX slim case as a LAN party box.
Zap- nice case. As an A100BB user myself, I once had that very same Enermax 320W psu. Had to give it up though since it didn't have enough juice to power an 8800GS. Switched to the Seasonic SS-350SFE that I have now which is still going strong with a 5770 (see sig).
Awesome, reasonable pricing on amazon. Good finds.
On Amazon too
Sometimes it's ass to live in Hawaii!
Congrats HaxEJxuK! Please give us your opinions and thoughts about it as soon as you can!
i'm super dissappointed in Amazon for D/Cing this product, they seemed like the most likely candidate for shipping to NZ.
