From what I've read so far, it seems that running in dual channel with three sticks of RAM with an nforce4 chipset is a no-go, correct?
I've got an Athlon64 3700+ (San Diego) on order, along with an ASUS A8N-E. I plan to reuse the 1GB of memory in my existing system (NF7-S nforce2 ultra).
With my NF7, I could run in dual channel as long as both channels had the same amount of memory. I run 2x256MB + 1x512MB. Would this same configuration run in the newer system I'm building, or would I be better of buying a matching stick of 1x512MB?
The Asus manual says something like "DIMM_A1+DIMM_A2 = DIMM_B1+DIMM_B2," so in theory it should work, but I'm not so sure about the limitations of the Athlon's memory controller or mobo chipset itself.
Thanks in advance.
Thanks in advance.
