Aug 25, 2010 #1 K Koslov [H]ard|Gawd Joined Aug 31, 2003 Messages 1,889 Sorry for the lame question but I'm arguing with someone that you can't put an AMD Socket 939 CPU in a Socket 754 motherboard and he says you can. You obviously can't, right?
Aug 25, 2010 #2 W W.Feather [H]ard DCOTM x4 & [H]DCOTY x1 Joined Nov 10, 2009 Messages 11,716 the person is a complete idiot.....you cannot put a 939 CPU into a 754 motherboard.....there are over a hundred more pins in the 939.....just say: "You sir, are an idiot" .....and be done with it
Aug 25, 2010 #3 R RamonGTP Supreme [H]ardness Joined Nov 9, 2005 Messages 8,150 Wont work. Different socket configuration, differnt pin count and deifferent memory controllers on the CPU's themselves. (dual vs single channel)
Aug 25, 2010 #4 M MrC4 [H]ard|Gawd Joined Feb 10, 2010 Messages 1,733 Maybe he is confusing AM3 cpus that can go in an AM2+ board. Either way, he doesn't have a clue.
Aug 25, 2010 #5 4 450 Fully [H] Joined Feb 19, 2007 Messages 20,977 +1 to the above replies. It won't work. EDIT: maybe he was thinking of s940 cpu's working in s939 sockets?
Aug 25, 2010 #6 S steelman2202 Limp Gawd Joined Oct 26, 2005 Messages 349 Well, you can, sorta you just have to have one of these...
Aug 25, 2010 #7 J jamesrb [H]ard|Gawd Joined Jul 29, 2004 Messages 1,051 Some people are [H] enough to make it fit. Functioning after it goes in is a different matter.
Aug 25, 2010 #8 W W.Feather [H]ard DCOTM x4 & [H]DCOTY x1 Joined Nov 10, 2009 Messages 11,716 that still doesnt put a socket 939 chip into a socket 754...
Aug 26, 2010 #9 Roberty Extremely [H] Joined Nov 30, 2001 Messages 46,002 Sure it'll fit. Just use one of these handy CPU installing tools and it'll fit perfect. If you still don't think you are computer savvy enough to do it be sure to give this guy a call: http://www.liveleak.com/view?i=57a_1266897963
Aug 26, 2010 #10 M munkle [H]F Junkie Joined Jan 16, 2005 Messages 11,799 ask this friend if 939 dots can fit inside 754 dots, all dots are the same size.
Aug 26, 2010 #11 W W.Feather [H]ard DCOTM x4 & [H]DCOTY x1 Joined Nov 10, 2009 Messages 11,716 lol, the hammer just made my day
Aug 26, 2010 #12 C Cat1yst [H]ard|Gawd Joined Jan 1, 2007 Messages 1,616 A pre school child will be able to tell you a square peg doesnt fit in a circular hole. You can MAKE it fit, but it usually doesnt.... work.
