legcramp
- Aug 16, 2004
SteelSeries OmniPoint
The SteelSeries OmniPoint is a really versatile switch: You can decide yourself, at what point the switch is going to actuate. The actuation distance can be set within the range of 0.4 mm and 3.6 mm for each key individually. This has been made possible by the use of magnetic sensors which measure the pressed distance at all times. The OmniPoint switches are linear switches, so their feeling is comparable to Cherry MX Reds. The first (and so far only) keyboard with OmniPoint switches is the SteelSeries Apex Pro.
I had the tenkeyless version. In less than 2 years, it failed 3 times and needed warranty service. After the 3rd failure, I didn't bother sending it back to Steelseries for service. I just tossed it and bought the Corsair K70 tenkeyless. It has similar switches to the AP's OmniPoint. So far, I'm really liking the K70. My last Corsair keyboard was the K65 Rapidfire. It lasted almost 4 years before I went with the AP. I gave my K65 to my sister who still uses it to this day.Does anyone have this keyboard? How does the adjustable actuation feel compared to brown switch? And the Steelseries software, any good?
Thank you for this, very helpful! My EVGA z20 had a key failure and I sent it in for RMA. The replacement is coming back tomorrow and I am currently using a Corsair brown switch K95 XT and I love it. I am going to sell the EVGA and plan to either get another Corsair K95 as backup or something different. Your experience simply makes me go and just get another K95 XT.I had the tenkeyless version. In less than 2 years, it failed 3 times and needed warranty service. After the 3rd failure, I didn't bother sending it back to Steelseries for service. I just tossed it and bought the Corsair K70 tenkeyless. It has similar switches to the AP's OmniPoint. So far, I'm really liking the K70. My last Corsair keyboard was the K65 Rapidfire. It lasted almost 4 years before I went with the AP. I gave my K65 to my sister who still uses it to this day.
It's definitely possible. Each failure was the same. Suddenly, the keys just no longer worked. No typing and no illumination. Oddly enough, the USB-passthrough port still worked. I liked the adjustable actuation, but maybe there's a flaw in the design. Or, I just got on an unlucky streak with the Apex Pro.I'm assuming the adjustable switches aren't all that reliable? The concept seems great. For gaming I like light presses, for typing I prefer tactile. But if the board starts having issues then it isn't really worth getting.
My full size version is 9 months old and is the nicest keyboard I've used.Does anyone have this keyboard? How does the adjustable actuation feel compared to brown switch? And the Steelseries software, any good?
This looks like a general failure as it impacts all keys simultaneously, the keys have very little to go wrong.It's definitely possible. Each failure was the same. Suddenly, the keys just no longer worked. No typing and no illumination. Oddly enough, the USB-passthrough port still worked. I liked the adjustable actuation, but maybe there's a flaw in the design. Or, I just got on an unlucky streak with the Apex Pro.
The OPX opti-mechanical switches on the Corsair K70 are not user adjustable, so we'll see if any unpleasantness develops.
