I just got a X9SCM-F-O, E3-1230 v2 and 4x4GB Kingston DDR3-1600 ECC (KVR16E11K4/16) I've checked and it came with the latest 2.0b BIOS, so it fully supports the CPU.
The system resets roughly every 5 minutes, regardless of what I'm doing. It doesn't matter if I'm in Windows, running Memtest, have it paused at the Windows F5 screen, etc. If I'm connected via IPMI, I stay connected and it continues to function through the resets.
I'm using a pair of WD Scorpio Black drives in RAID1 for the OS, and I've noticed the resets seem to happen more frequently with both drives present, but it still happens with only one (perhaps because it's attempting to rebuild the array?)
I called Supermicro and they said it could be a PSU issue, or memory if it continues with a different PSU. I'm going to try a different PSU tomorrow (I'm using a brand new Seasonic X750 right now, but I'll use a known good Silverstone ST60F to test)
Unfortunately I don't have any other DDR3 Unbuffered/ECC RAM to try but I'm guessing that's the culprit. I''ve tried using a single DIMM in slot 1A and it still happens. I know a few on here use this board for ESXi so I'm wondering what some known working RAM is.
Thoughts? Suggestions? Any insight would be very helpful.
