I'm trying to figure out whether my 1800X on the Asus Prime X370 Pro is behaving normally or if something is wrong with the cooling.
When running 8/16 threads it boosts to (and sustains) 3.7 GHz as expected, but it's not sustaining ~4 GHz when running single threaded workloads. It still only reaches 3.7 GHz sustained.
Complicating matters, I can't get any reliable temp readings.The previous BIOS shows 30-ish idle, 58C full load, but the latest one shows 56C idle, 74C full load. Obviously the latter numbers are way too high, but I don't know whether they are accurate. If the CPU was overheating, why would it boost to 3.7 GHz in multi-threaded workloads? Wouldn't it stay at 3.6 then, or even underclock itself?
I don't want to rip out the heatsink and get a new one if it's actually a BIOS issue. I am using the PH-TC14PE with an AM4 mounting kit that uses the stock backplate, which according to some is a problem, but on the other hand I've also read that boost might not work properly with some BIOSes.
Would appreciate if someone else could check their clock speed while running a single-threaded task like Furmark CPU stress test @ 1 thread, or Cinebench single threaded.
