As part of my ongoing plan to bankrupt myself and my immediate family, I'm once again revamping my main/gaming rig build. As some of you may know from a previous thread, I got a Rampage Formula awhile back along with a QX6850.
Well, a BIOS flash failed and so I've RMAed the mobo. A mostly-empty case, as it turns out, is very dangerous for me...it makes replacing things easier, which makes me much more likely to do the work. In other words, spend too much money.
So here's the new build, which is supposed to be as powerful and as quiet as possible. I'm swapping out the stock heatsink for a TRUE copper, which I will mount with 2 Noctua NF-P12 fans. I'm getting a GTX260 (newer 216 edition) which I will retrofit with the new HR-03 GTX VGA cooler once it comes out. I'm also replacing the gaudy, mid-range fans in my Antec 900 with Scythe S-FLEX SFF21F fans. (I just don't need a giant blue nightlight in the corner anymore!) And obviously I'm going to move into a better power supply, probably a CMPSU-620HX.
The problem, I guess, is that the TRUE Copper is extremely heavy at 1900 grams (especially with the 2 fans) and the card will be rather large/heavy as well (especially with the aftermarket cooler.) I'm a little worried for my motherboard! Should I move to a horizontal orientation, throw some rubber feet on the side and call it a day? Is there any particular hardware I can install to support things better? I've heard of things like foam backings but I've never seen any.
I think, once this build is complete, it should fulfill my objective of very low noise paired with good speed, horsepower, and overclockability. Assuming the thing doesn't crack in two!
